1 - 2 of 2 Posts
Hi,
I have an oil and coolant leak in my 2005 Pilot that seems to be coming from the rear cam cover so I am suspecting a head gasket so I need to do a compression test. The Service Manual says I will need to reset the PCM with the HDS following the test because the fuel injectors will be turned off, but of course I don't have a HDS to do that.
How can I reset this without the HDS? I have seen various possible solutions (remove PGM-FI relay 2, disconnect negative battery line, disconnect both battery lines and short together). Does anyone know for sure what will actually work or a reference section in the Service Manual that I can follow?
Thanks a ton.
Keith
Can you get to the injectors to unplug them? On my '04, I'd probably have to take off the intake manifold to get to them, but I'd do it if I had to reach them for a compression check.
I assume the HDS allows you to turn off the injectors to prevent this effort, so it needs a reset to turn them back on?
1 - 2 of 2 Posts
