Hello fellow Pilot owners. Question pertaining parking breaks. I've completed rear rotors/pad swaps and wonder if the parking brake needs an adjustment after performing it. I had no issue taking the old rotor off (no drag between the inner surface or the rotor and the shoe). After installing the new ones no drag either (wheel spins freely) and it takes 4-5 clicks to full engage the parking brake. So, the question is, does parking break needs and adjustment or leave it as is?
thanks
If you park on a cline in neutral with pbrake on, does the vehicle roll? If so the yes, if no then no. Slowly coasting backwards and applying the parking brake should set it.
no Sir, it doesn't roll and holds it just fine with 4-5 clicks on the parking brake
