When we first got our Pilot, by mistake I set off the panic button on the keyless entry fob. In the last week I was trying to do it on purpose (just to test it) on both fobs and NOTHING. Anyone else have this problem? Did I have to reset it after setting it off? Please help - I like to know it's there if I ever really need it.
I make same mistake too ...
First time it was embarrassing because I didn't know how to stop it (turns out just press any button). No I don't run into the problem you have, as mine works all the time (still making this mistake). You must have a spare one. I received two when I got the Pilot. Have you tried the spare one too? If it doesn't work, you should take it to the dealer for warranty.
I believe your doors have to be locked for the panic button to work.
I use it occasionally to help find the Pilot in a crowded parking lot. Or you can use the lock button over and over which creates the less obnoxious chirp instead.
There's a delay
There's about a 1-2 second delay in the PANIC button. There's also a delay when trying to turn it off. I got kind of confused by it at first. I kept getting impatient when trying to turn it off and I'd press it again and turn it back on.
Re: There's a delay
oh man, I did the same thing. I was in a panic after trying to turn it off and realizing I was hitting the panic button over and over!
Just relax and don't PANIC:eek:
Re: Re: There's a delay
OK, I'll try not to panic next time. :D
