1 - 15 of 15 Posts
I have a 2005 Honda Pilot. I’ve changed the thermostat with original parts. Car act like it want to overheat when I stop and sometimes it slowly goes back to normal. When I turn car off the fan come on but smells like rusty hot water I guess. There’s coolant in the reservoir but it doesn’t look like any is in the radiator. What could be wrong?
Don't drive anymore it until you get the radiator and hoses changed, for that and other reasons on a 2005.
When you replaced the thermostat did you burp the air out of the cooling system after you added coolant? Perhaps you have a trapped air pocket in the system which isn’t allowing the engine to be properly cooled down.
Also when you turn the Pilot off and walk to the hood area do you get a whiff of a sweet smell (leaked coolant which has cooked)?
Not sure if it smells sweet but I do smell something
[/QUOTE
Not sure if he did. It was changed months ago.
+1 on properly burping the system. Sometimes a pocket of air will get trapped near the temp sensor and cause your gauge to read incorrectly.
I use one of these funnels and it makes burping a radiator so much easier.
How old is the radiator?
Open up a bottle of coolant and smell it. Imagine what it would smell like if warmed up and slightly burnt. It’s a fairly distinct smell. Since you see no white smoke, look on the radiator for any blue (assuming there is Honda Type 2 coolant in the radiator) chalky substance on the radiator fins or base where metal meets plastic. If you see this the radiator is leaking.
But my money at this point is still on air in the cooling system. Did you bleed the air after replacing the thermostat? Or asking another way how many times did you fill the radiator and reservoir after replacing the thermostat? If your answer is once then likely there is air in the system.
placing bets on the Rad being shot since it's an 05 and we all know they are bad for that year
When you fill the coolant into our engine, you have to step on the gas pedal at least once to burp the air.
To burp--turn on the engine, wait for the coolant to boil over (while you sip your tea), then turn on the heater for a few minutes while refilling the coolant (you may have to do this a few times) then replace the cap. Drive the car around the neighborhood a few times while watching the thermostat.
Discussion Starter · #13 ·
[/QUOTE
I drove the car today and the Temperature gauge went up again. I put the car in park and look under the hood and the fans were not on. Once I cut the car off the fans started working.
OP, I’m going to suggest you read through this entire thread and answer the questions people are asking. Your answer will provide useful information that we can use to help you diagnose the issue.
The engine coolant temperature spiking multiple times is not good for the overall health of the engine.
If your fans are not turning on, use AC as a workaround until you figured out the root cause.
Max AC, max heat at the same time, and it should make it.
1 - 15 of 15 Posts
