I'm kicking around the idea of starting an extended tune-up service on 1st gen Pilots. I would like to do the service at the customers location, but I might have a place to work on them if needed. It would be these services below. I was wondering what I should add/remove, and what would be a good price. I would provide all of the parts/fluids. Would need to figure in travel, consumables (gloves, paper towels, lubricants, electricity, damaged tools, etc...), and time.
-Valve lash
-Valve cover gasket and associated seals
-Throttle body cleaning and gasket
-EGR system cleaning and gasket
-Spark plugs
-Coil pack health check
-Check engine mounts and advice
-battery health check and cleaning, and associated wires to: Alternator, Starter, Main fuse box, and Ground wires
-Inspection of vacuum and cooling hoses
-Cabin/Engine filter replacement and cleaning housing boxes
-All fresh fluids (Power steering, brakes, transmission, engine, coolant, rear diff, and if equipped transfer case
-Transmission/engine filter
-Radiator Cap
-PCV valve
-Health check Serpentine belt
-Health check pulleys
-Health check Timing belt
-Inspect brake system and advice
-Inspect suspension and advice
-Check Rack and Pinion and advice
-Inspect tires and inflate
-Clean wheels of road debris
-Rotate tires
-Inspect lights and replace burned out including interior
-adjust headlights if needed
-Grease hinges
-lubricate door/window seals
-inspect windshield wipers and advice
-bench test/clean transmission solenoids and advice
-check throttle cable and adjust to preference (tight/slight slack)
-check for leaks and advice
-ATP AT-205 power steering, engine, and trans fluid
-check exhaust and advice
-inspect everything is where it should be and nothing missing and advice
-install missing hardware (clips, screws, bolts, etc...)
-check torque on critical components
-Road test and advice
-Check steering components and advice
-Check rubber joints and advice
-Check ball joints and advice
-Check for rust and advice
-Check wheel bearings and advice
-Check CV axle and advice
-Check drive shaft and advice
-Replace power steering O-rings if leaking
I'm thinking maybe after the initial extended tune-up setting up a schedule to maintain them after. Oil changes, inspections, re-torque, etc... Once all of the above is done, not much more then regular oil changes would need to be done for at least a couple years. Create a profile for each vehicle to refer back to.
I'm sure I'm missing some things. I don't think I want to actually fix any of the advice items, unless they are easy enough. I'm thinking 1-2 days, hopefully get proficient enough to knock it all out in a full work day eventually. Except you never know what you will encounter. Maybe schedule 2 per week. Monday and Thursday and work into Saturday if need be. Take Wednesday off if lucky.
How much would you all pay someone to do the services above (like any of you would have someone do any of the work above, lol)? Would you allow someone to work in your driveway?
