1 - 2 of 2 Posts
Our 2017 Honda Pilot has 10% oil life with only 4.6 K miles since last oil change with a mix or around town and highway driving. In our previous first generation Pilot, I would change it anywhere from 8 - 10K miles
Is the MM (Maintenance Minder) in the newer Pilots too conservative?
Have you been driving the last year or so as much as you did before Covid? Oil life is not just calculated by mileage, but the type of driving being done as well as time. If you read the manual in the MM section it will tell you to change your oil once a year regardless of mileage.
1 - 2 of 2 Posts
