2014 Honda Pilot (4WD, 71k), 2014 Honda Odyssey (59k)
I found a set of like-new 2012 Odyssey 18” Touring Elite rims, and was trying to determine if they’re compatible with my 2014 Pilot EXL. The Google told me that they have the same tire size (P235/60R18), but the rim sizes are different - the Ody is 18” by 7”, and the Pilot is 18” by 6.5”. Would it be a simple 1 to 1 swap from the Ody to the Pilot without any issues, or does that .5” make a difference?
Ifit’s not apparent, I’m pretty clueless about wheels and tires.
Super Moderator
If the bolt pattern of the oddy/pilot are identical the 0.5" wider wheel should not be an issue. The offset of the wheels is a more important factor and if they are similar it will be fine.
I wasn't aware that there was a "touring elite" Ody in 2012. Live and learn!
Meanwhile, those rims will fit just fine.
Reactions: FatherPercy
That's good news! I'm between the Ody rims and a 3rd gen set of Pilot rims for my '15. Hopefully I'll be able to snag one of them soon!
