1 - 1 of 1 Posts
Hi everyone,
I've been searching to see if any one else had any similar posts, but wasn't able to find anything. We are experiencing an intermittent noise from the front of the vehicle. It sounds like a short grinding noise or something similar. It generally only lasts a second or two and there's no pattern that I can identify. It seems to occur more at lower speed levels (I haven't heard it on the freeway, but that could be because its too loud). I've linked a video clip below so you can listen to it for yourself, you may need to turn the volume up a bit, but you'll hear it pretty quick (between 1-2 seconds in). Any ideas on what I should tell the dealer would be appreciated. Thanks in advance!
Short Video With Unknown Noise
1 - 1 of 1 Posts
