1 - 10 of 10 Posts
Very odd noise coming from behind the dash. Hard to describe, but almost like what an 8 track player or cassette used to sound like. I haven't a clue. I guess I can just keep the music louder .
It can be a number of things. Is it cyclic or steady?
The blower and mixer door motors come to mind, as well as the CD player.
Does turning things on and off throughout the dash change anything?
Sorry Can! I must not have my notifications set correctly. It's more steady. Maybe something to do with heater core if that is behind there. Maybe I should check CD player. I never use it but also never thought to check to see if it's empty or just spinning in there .
My first thought is that you need to identify what causes the noise to occur (fan on, ac on, heater on, etc) and provide a more precise location of where it is coming from. Then we’ll be able to provide better feedback on what to check.
What @road2cycle said. I can think of the hvac blower, or blending motor, maybe a CD?
More Ex:
-radio on, volume down, hvac off
-radio off, hvac on
-radio off, hvac off
-engine on or off in II
-driving or idling
-hvac settings
-rear hvac settings
My 04 had a weird noise in the center of the dash like you are describing. It was the AC blend door actuator. I found it by having the Pilot and AC running. Lay in the passenger side floor and reach your hand under the center of the dash and touch the blend door actuator. I shined a flashlight under the dash to locate it. It is on the bottom of the air box.
By the way how do I set my notifications so that I do get notified when there is a reply or activity on a thread I'm following? I thought I turn all notifications on but nada .
Account -> Email option (select preferences) -> Go down to the section where it says “Receive a notification when someone . . .”
1 - 10 of 10 Posts
