Hello,
Which part for the forward O2 sensor works with the 2006 Pilot?
Which part for the rear O2 sensor work with the 2006 Pilot?
Apparently, KAX O2 sensors (250-25001), as identified by Amazon, don't work. They produce computer errors about low voltage. Plus, they trigger 84-1 and P119-1 errors with VSA and the Yellow Triangle.
For O2 sensors, best to bite the bullet and buy OEM.
And you can get the NTK or the Denso (avoid the Bosch) here for (much) cheaper.
Welcome to the forum. Please help yourself to the 5% discount.
5% Discount Code: 31517DFA058403
Expires: February 12, 2021
Miss our 2005 Pilot
I second Majestic Honda. I have always had good experiences when purchasing parts from them.
Denso on RockAuto.
Reactions: cloudasc
I used rock auto to lookup the proper part number then ordered that part direct from amazon to utilize my paid prime shipping service :)
I used Denso for both AF (front) and o2 (rear). I would also have no problem using NTK/NGK. I believe the Denso's are made in USA while the NTK are possibly made in Japan?
Do not stray from these 2 brands if you can help it use another source or wait a little longer for shipping time
Super Moderator
HF has the O2 sensor sockets cheap and effective. However since you are replacing them cut the wires and have at it with a regular socket. Anti seize will be helpful for the next time.
Agree.
The socket is needed to torque to specs. 33 ft lbs.
