1 - 12 of 12 Posts
Hey all,
I've searched this previously but just need the help now.
My wifes 04 pilot has had intermittent starting problems. Occasionally it just clicks. She turns the key to 1/2 for a bit, then it starts.
This morning it did nothing but click so she had to take my truck.
I put the battery on the charger and it was at 95% & just around 12 volts. It's 5 years old so I decided to just go ahead and replace it.
It's on the charger now at 99%, but the car still just clicks.
It did start this morning after charging the old battery.
Where do I start next? I've heard checking out the starter relay and/or ignition switch?
I'd check all the ground cable/straps for corrosion or breaks. Clean connections.
  • Negative battery cable to chassis
  • Engine/starter to chassis
  • Transmission to chassis
If discovered that replacement is needed, Wal-Mart has some inexpensive alternatives. (Determine lengths)
Product Liquid Gadget Audio equipment Street light
Sometimes the fix may be something simpler. Last time I had an intermittent start it turned out to be a bad ground wire. Based on the age of the Pilot there is a chance the problem may be similar. Take a peek down under and check all the cables.
thanks for the replies. I recently replaced the battery terminal connectors and none of the ground or positive wires are in anywhere near as a bad of shape as the previous pictured ones.
The new battery has been charging for a few hours now. Still just clicks....
Looks like I may be replacing a starter tonight.
Based on your description of the symptoms, your starter has been dying. Its time though for a new one. Its located right under the battery......
Similar things happened to me on my boat. It was just a loose connection on the negative battery cable.
Load up the connections with dielectric grease and crank them down.
Make sure you have a long breaker bar. Getting those two starter bolts loose is the toughest part of the job.
Reactions: aggrex and plplplpl
All good advice here. I can't not like any of it. (y)
Discussion Starter · #11 ·
Quick update, I ended up replacing the starter with an autozone lifetime warranty unit. The job was pretty straight forward & easy. I did notice the long ground cable that goes from the battery to the block below the starter was little frayed. It was not bad, but slightly corroded & frayed so I replaced it.
Now I have a new battery, new battery terminals, new ground cable & new starter. So far so good. I've started it probably 15 times with no issues...
So you've earned the Piloteers' coveted successful DIY repair happy banana dance.
Toy Beard Electric blue Event Font
1 - 12 of 12 Posts
