1 - 2 of 2 Posts
This is a different problem from the ignition thread. I just realized that the second black key I got with the Pilot does not insert fully into the door lock or ignition. It appears to be the same on close inspection, but it doesn't fit. Back to the dealer for another copy.
This happen to anyone else?
Assuming the door is the same as the ignition, no problem here. Never used it on the door.
One test I want to try is to see what the valet key can do. Had a 1993 Mazda 626 where the valet key could open the glove box it you only inserted it half way. Must have been a simpler lock and a bump at the right place on the valet key could unlock it. Now if I was only rich enough to have something valuable to put in my glove box and take it somewhere expensive enough for valet parking!
1 - 2 of 2 Posts
