1 - 17 of 17 Posts
OK, here is my question: My 03 Pilot has 238,000 miles on it and, to my knowledge, the valves have never been adjusted. Should I leave well enough alone or should I have the valves adjusted. I understand from the various YouTube videos I have seen that this is sort of a big deal, requiring the removal of everything on top of the engine. So, should I get it done or leave well enough alone? Thanks for your suggestions and comments....
How's your gas mileage? Did you ever check compression?
Gas mileage is around 10 or 12 but I live in Guatemala so am unsure of the quality of the gasoline here. The compression was pretty even.
Removing the stuff isn't really the big deal. It's hovering over the valves trying measure with the feelers and loosening and tightening that is the PIA. My '04 has 199,000 and I just had the valve covers off to do the gaskets and I left the valves alone. It's still getting pretty good gas mileage right at 17mpg.
I have never seen that kind of mileage, even back in the US when I was, presumably, burning decent gas. -
Just my judgment, but if you're a decent mechanic and familiar with the general process of valve adjustment (e.g., have done a motorcycle or two in your youth), then I'd do them. Or if you have a good mechanic you trust, same. But otherwise, I'd just continue to run the vehicle and hope for the best as the odds are that you'd do more harm than good.
- Mark
In the hot Guatemala it should be at least 15. I would bite the bullet and do the adjustment provided that all other maintenance items such as TB, plugs, coils, air filter, intake air duct etc are fine.
No misfires, I assume? Have you ever cleaned the EGR trenches in the intake cover?
Well, the good thing about Guatemala is that labor is ridiculously cheap. When I returned from a recent trip to the US I had my suitcase stuffed with suspension bushings. Now the car is so nice I may keep it till 300K and beyond. I have a good mechanic and I will probably get him to do the valves. EGR trenches? Never heard of 'em but I will look them up. EGR valves, for sure.
Read Only
I would adjust the valves, they are probably tight, they were tight on my pilot with 235k.
I wouldn't replace the EGR, but I would take it off (2 bolts) and clean it. You will get a check engine light if the EGR isn't lifting/opening correctly.
Wow, thanks. I never knew about that particular source of bad running. Tell me, when you put that cover back on, is it supposed to have a new gasket,? Anyway. thanks again.
Any truth to the theory that a higher percentage of corn juice, AKA ethanol, in your gas contributes to increased fowling of EGR ports?
Yes, you have to put a new gasket on as it its metal is coated with rubber and once that rubber peels off you have a vacuum and oil leak.
Reactions: Winterspilot1
Read Only
Took mine off 3 times and it’s perfectly fine. If it doesn’t look damaged you’re fine. Just don’t put it back on upside down. If it runs differently you’ll know where the source is and can replace at that time.
And I took mine off once, rubber was peeling, and I had a leak even after proper torquing of the bolts. New gasket solved id. YMMV.
Is this supposed to help with getting better MPG ?
1 - 17 of 17 Posts
