I am aware there have been documented problems with the original head unit in the 09 Pilots. Mine started intermitently but now seams out for good. You hear a small pop when you turn the ignition but then nothing. head unit powers up fine and you can hear the sub but that's it. Was thinking it might be an issue with the amp and not the head unit but I have no idea. Any insight on where to look would be appreciated.
pf
What is the trim level? Is it a premium (with amp) or not?
EXL. It has the AMP. I discovered another post with a similar problem. The issue was the drivers side passenger door speaker. I had recently replaced the speakers and one of the wires was disconnected. Re-connected and worked as it should. Happened again a few weeks later. I took the time to re-wire with better connectors and has been fine ever since
