Yes, it's saving my Honda's x 3.So its worth buying the VCM?
What does it do tho? Less tear on the engine I would assumeYes, it's saving my Honda's x 3.
When all 6 cylinders a firing 100%, it makes for a cleaner engine, valves, injectors, spark plugs, EGR valve and exhaust system.What does it do tho? Less tear on the engine I would assume
But ever so slightly worse fuel economy...When all 6 cylinders a firing 100%, it makes for a cleaner engine, valves, injectors, spark plugs, EGR valve and exhaust system.
Thanks for explaining it. Ill look into it and will consider it. Yea for sure I want it to run it on 6 cylinders all the time. You have a good link to where I can look into those VMC?When all 6 cylinders a firing 100%, it makes for a cleaner engine, valves, injectors, spark plugs, EGR valve and exhaust system.
I see.See link on comment #14. I use S-VCM.
GEOLANDAR A/T G015 | Yokohama Tire CorporationEspecially if I want all terrain tires too with no rubbing. Is that even possible.
Lets say I go 17's, mean I can go bigger size tire?GEOLANDAR A/T G015 | Yokohama Tire Corporation
You can get these in the same size as the OEM tires, so no worries about rubbing.
Are you:Lets say I go 17's, mean I can go bigger size tire?
Nah none of that lol. Maybe more like simple sleek thats all. Mostly camping since I do that a lot. Planning to add some wheels, roof rails and a rhino rack canopy thats all. Just needed suggestion on the wheel size and how I should do it. Any info would not hurt thats how I look at it.Are you:
Planning to tackle the Rubicon Trail?
Trying to make the Pilot look like a monster truck?
Turn it into a dune buggy?
IMO, skip the new wheels and change only the tires if you're going off pavement on a regular basis.Nah none of that lol. Maybe more like simple sleek thats all. Mostly camping since I do that a lot. Planning to add some wheels, roof rails and a rhino rack canopy thats all. Just needed suggestion on the wheel size and how I should do it. Any info would not hurt thats how I look at it.
Welcome and thanks for registering at piloteers.org. We are glad you have chosen to be part of the community and we hope you enjoy your stay.2021 Special Edition. My first Pilot View attachment 139811 View attachment 139812 View attachment 139812 View attachment 139814
