I recently bought a 2014 Pilot Touring with 180,000km on it. I knew the timing belt and water pump had not yet been done so I have done the following. This is my first Honda any other recommended maintenance items I am missing?
Done:
Timing Belt
Water Pump
Cam Seal
Drive Belt
Brake Fluid
Power Steering Fluid
Transmission Fluid
Rear Differential Fluid
Front Transfercase Fluid
Spark Plugs
Air Filter
Cabin Filter
PCV Valve
I am not looking to spend money as I have already spent a crap load just want to make her last.
Are you going to DIY?
I wouldn't touch the crank and cam seals unless they are leaking. Leave it for the next timing belt water pump job.
Dump old coolant out of radiator when replacing water pump.
Miss our 2005 Pilot
Vacuum the air filter screen for the rear blower. It’s likely clogged since it’s not a standard maintenance item. Your rear seat passengers will be grateful.😁
And enjoy your new to you Pilot.
Reactions: The Todd
Miss our 2005 Pilot
