Recently picked up an 05 EX-L for my daughter. Planning to do the timing belt, water pump, tensioner, idler tomorrow (using the Aisin kit) - also replacing the plugs (NGK Iridium), thermostat (and obviously the coolant) as well as the serpentine belt and tensioner, filters, etc.. Went with aftermarket almost everything (Aisin for the timing belt - have used this several times on our old and current Odyssey - it's a great kit), I think I went with continental for the serpentine belt, gates for the tensioner and thermostat, etc. - all through rockauto (to eliminate counterfeit concerns with the plugs) - everything looks nominally identical to the 05 odyssey I did this on (twice...) in the past - looks like easier access for some things, and maybe the rear plugs will be a pain lying over the engine...
Anyway - are there any gotcha's I should be watching out for? I am pretty comfortable with the timing belt fiasco (only annoying thing really is the crank bolt...), using honda coolant, etc. (the pilot has just shy of 200k miles and has been pretty meticulously maintained)
