For years, the front dome lights didn't come on when the door was opened.
I read about it over a year ago, and seeing the link for the switches I ordered them and changed them out.
Well SOB, Now the front lights WON'T WORK when you push the map light on!
Door open- both work- check.
Turn the interior lights 'ON' with the left hand switch- both work- Check
Try pushing the dome light- that came on before I changed the switch?- Nothing!
SOB.
Is it now the bulb?
Pretty straightforward install, took literally a few minutes. I fixed the one thing- coming on when the door is opened, and messed up the manual push it on/off?
What did I do wrong?
Discussion Starter · #2 ·
So the planets aligned.
I took it apart again, bent the prongs back kind of where they were, reassembled, it works as intended.
Now to figure out how to replace the bulbs inside some of the dash controls on my 08 pilot. Yes I know there are quite a few threads on it and I will start researching it soon.
