To me, it’s all about the pressure relief valve. To soft and your filter will let the oil bypass. The more used the filter, the greater chance of this occurring.
Every dealer probably has their own pricing. The A02 filters I got last fall at my local Honda dealer were $8.56 each.Anyone buy their filters straight from the stealership?
Your thoughts? Does any of this matter... probably not!
I thought that whole idea behind the bypass valve was to avoid oil starvation at the bearings during start-up when the oil is cold and thick, not flowing well through the filter media? So long as the pressure rating is in the same range as OEM all should be well ? Unless we have a way of independently testing each filter we buy, we are simply assuming that the numbers provided by the manufacturers are accurate and true.To me, it’s all about the pressure relief valve. To soft and your filter will let the oil bypass. The more used the filter, the greater chance of this occurring.
Yes, but as you research, you will find that some are weak on this rating. Wix for one. I’m currently using Purolator One.we are simply assuming that the numbers provided by the manufacturers are accurate and true.
