I just replaced front brake pads and rotors on 2004 Honda Pilot and when we take right turns we can hear a faint scraping / ticking (at low speeds) and the scraping noise is louder when taking a right turn while braking. Scraping noise is coming from front passenger side
Thoughts on how to solve this?
What brand pads and rotors?
Did you put all of the shims back on and did you apply the supplied grease? You should. If you did, then did you torque all of the bolts properly?
Powerstop rotors and Monroe pads - I applied shims and greased the back of pads - i may have to re-visit the bolts to ensure they are tight enough
The scrapping noise for me was the backing plate. It was there when turning to my right. It was discovered by the tech when installing new brakes. You may have inadvertently bent it while installing new brakes. If that is the case, just push it back away (to straighten it) from the rotor. Thanks.
