I have experienced the following scenario 3 times now. The fix is easy, but I'd like to get to the root of the problem. Vehicle functions normally for 2 weeks. Get in to start the vehicle and the dash is completely dead and will not even try to turn over. Interior lights work, key in ignition bell works, headlights work. Battery is new. Solution- Disconnect the negative terminal and reconnect. Fires right up. Anyone have any insight?
Thank you!
First though is loose connection somewhere. Check all the ground cables and make sure they are tight, not corroded or fraying.
