1 - 1 of 1 Posts
So both my low beam headlights went out the other day. High beams still work, day lamps are on, fuses, bulbs and relays all checked out fine. Tried changing the combo switch for the headlights and still nothing. I know the combo switch basically completes the ground so that the relay is activated and turns on the headlights and that there’s a way to bypass this so the headlights come on. I just need a wire diagram of the harness to find the right wire to shunt to the ground wire.
1 - 1 of 1 Posts
