I have a 2005 ex-l with the rear dvd player option. I'm curious if I can add the factory navigation (or aftermarket) and still retain use of the rear dvd player?
I beat this one to death, too, and concluded surgery on the RES hardware is not feasible. You could go aftermarket, rip everything out of the dash and have an input for the DVD player, but you will probably sacrifice all the audio controls on the steering wheel. Even the bluetooth interfaces others rave about are out if you want to keep the DVD working - it uses the AUX input on the head unit, if I recall correctly.
A really good audio guy could probably deliver a clean solution where everything works correctly, but I suspect it would cost more than I paid for the vehicle. I gave it up.
