So my wife LOVES to honk at people, so I thought about installing a little surprise for her and put a set of hella horns in for her. What I need to know is the best place/way/tactic etc to get these attached. She has a 2011 Pilot touring. I've read that I'm going to need to wire them to the battery, but I've also read I can use the existing connection for the stock horn. Any advice would be appreciated.
So I guess installing a federal air horn would be out of the question ?
LOL
Add a relay using the wire to the stock horn as the trigger.
The actual power to the horn comes straight from the battery with a fuse.
PS Not responsible for any divorce etc that results from you doing this...
Don’t forget to post a video after you do the install.
Install a compressor and install a set of locomotive train horns... not sure if that would increase the want to honk someone
Does she honk a people for the hell of it or does she do it because there's a reason for it?
Hopefully it's not for a booty call :p
