1 - 20 of 43 Posts
I figure I will post up my experience, and a few tips that might help. I decided to tackle the timing belt this weekend. 106k miles, right at 8 years old. We have owned it since 52k miles.
I have never done a timing belt before.... but I have turned a fair amount of wrenches on personal vehicles. My biggest concern was not the work or the time involved - it was if you messed this up - the results could be catastrophic. I read several threads here, and then watched about 6 youtube vids to prep.
Aisin TKH002 from Rock Auto for about $170 shipped.
Bando 6PK2135 Belt from Amazon (B000CMCNJC) for $22
BETOOLL 50mm Crankshaft Crank Pulley Wrench Holder Tool from Amazon (B01F333OHY) for $14
EPAuto Spill Proof Radiator Coolant Filling Funnel Kit from Amazon (B01I40ZQWE) for $23
Paint pen marker squeeze action from Amazon (B004BF5P6O) for $5
I read too many horror stories of broken bolts in blocks, so I ordered the primary bolts I read that broke. I believe most of these were caused by not using a torque wrench, but who knows. It was cheap insurance.
14513-RCA-A01 Bolt Timing Belt Adjuster $8.42
14551-RCA-A01 Bolt Timing Belt Idler $6.50 (this came with red loctite already on it)
95801-06030-07 Bolt Flange (6X30) for tension-er $1.35 (need two)
Mostly just hand tools, my 25 year old Craftsman socket set still seems to do the job after all these years. I did make use of several additional socket extensions from a harbor freight kit.
It took me about 8 hours of actual work time. I was surprised.... I figured I would do it a lot faster. But some things were slow, and putting everything back together just took a lot longer than I expected.
I didn't have any significant issues. Pulling the drive belt was a pain from below. Much easier from above I found out later. I wish I would have just ordered the harbor frieght (or amazon) tool for the serpentine belts.... to make this easier to remove and reinstall.
FIRST - I saw too damned many videos of people working way too hard to bust loose the crankshaft bolt. Wasting hours of time and energy. I was at first planning on getting the special heavyweight socket, and buying a Milwaukee 1400 ftlb impact, which is a $400 expense, but a guaranteed removal. I saw enough "bumping the starter" videos to determine this is what I would do. I took a 1/2" breaker bar and a 19mm impact socket, and rotated the crank so that the breaker bar was right up against the control arm (NOT the driveshaft!). I used a small bungee cord to hold the breaker bar in place so it would not fall off. Then went and bumped the starter (with coil packs unplugged) and did this FIRST thing..... as I wanted to ensure I could get this loose before wasting time on anything else. I popped loose on the second hit of the starter.... but you have to switch off that key, as the computer will continue to crank if you just let go. It was super easy... about 5 minutes of setup time. If you have an amazing impact, then the $20 special impact socket is the way to go.... but since I didn't, I figured I should give this a shot first. YouTube
The hydraulic timing belt tensioner was really leaking... LOTS of oil showing up.
The idler and tensioner pulley bearings both felt ok, but both showed evidence of oil/grease seepage coming from the back of the bearings.
The biggest surprise was the timing belt idler pulley bolt. When I removed it - a small amount of engine oil seeped out, and there was evidence of motor oil on the threads, on the end, ahead of the threadlocker evidence. I never saw anyone mention this - that this bolt hole goes into the engine oil channels.
My drive belt tensioner was showing evidence of leaking (black gunk all over) but the bearings felt fine, so I elected to just reuse it.
I was struggling to find the right belt routing image when it was time to put that back on - so putting this one out there....
On the tightening of the crank bolt - hitting the 47 ft lbs was super easy. Then, I marked a corner point of the crank bolt, and then just make a mark on the crankshaft pully "hexagon" that would be 60 degrees (one "flat" basically) since there are 6 flats/points, each one represents 60 degrees. My crank tool fit ok, and with a smaller 1/2 breaker bar it was easy to wedge into place, then put my harbor freight breaker on the 19mm socket, and had to use my foot to push it to get enough leverage. I got it to about 50 degrees and said "close enough" because that is REALLY tight. The torque spec without doing 47lbs plus 60 degrees is equivalent to 180 ft lbs..... which is a lot. You apply motor oil to the crank bolt threads, and the back of the bolt head (in between bolt head and washer).
These are my notes I made for myself from watching the videos, and basically what I followed.
Jack Pilot and place on jack stand. Remove passenger side tire off to gain access to crankshaft (22MM socket on lugs)
Remove clips (x3) and 10mm bolts (x4) on fender well skirt to gain access. Fold back and secure with bungee cord.
Remove engine top cover
Un-clip spark plug coils to disable engine start.
Bust loose crank pulley bolt using starter method (19MM socket and breaker bar)
Remove drive belt
Remove drive belt tension-er (12mm bottom and 17mm top)
Remove access panel to drain coolant, drain
Relocate coolant overflow tank off to side
Disconnect power steering pump reservoir hose at pump, use paper towels beneath to catch any spills
Remove power steering pump (12mm deep socket x2 with a 1" extension)
Un-clip power steering reservoir and relocate
Remove 3 bolts from computer module and swing module out of the way to clear motor mount
Remove upper timing covers - moving the wire harness out of the way first (x5 10mm bolts for each cover)
Remove crank pulley bolt and pulley.
Remove lower timing cover (10mm deep socket x7)
Remove timing belt washer shield
Reinstall crank pulley bolt to turn engine
Support engine with a jack with block of wood on oil pan
Remove right engine mount bracket (mount to mount) - First with the thru-bolt, then 2x14mm to engine mount
Remove right engine mount to frame (swing computer module out of the way) (3x17mm)
Remove right engine mount to engine (1x10mm, 3x14mm to engine)
Remove coils and plugs to make engine easier to turn (optional)
Align timing belt per instructions according to timing marks with paint pen.
YouTube
Triple check alignment
Grind down a threaded battery holder rod per the Honda service manual, remove tension on the timing belt
Remove timing belt
Remove the hydraulic tensioner (2x10mm bolts).
Remove the tensioner pulley (you will reuse the inner sleeve) (14mm bolt).
Remove the idler pulley bolt (14mm bolt with thread locker on it)
Remove water pump bolts (10mm) and pump, allow to drain. Mind the alignment pegs
Clean water pump flange surface on engine with rag, if needed fine paper
Replace pump (mind the dowel pins), 5 bolts (10mm), 8.9lbs (108 inch lbs)
Rinse with hot water, and blow off anything that got anti-freeze on it. Final clean area with a rag and brake parts cleaner. Blow off again.
Install NEW idler pulley/bolt with loctite, 33 lbs
Install belt tensioner pulley bolt, 18lb, 14mm
Install hydraulic tensioner, 10mm, 8.9lbs (108 inch lbs)
Check alignment, install timing belt
-Install belt on crank first, keep tight to front with no slack, around front cam, down under pump, up around rear cam, with slack to the rear.
Check alignment again.
When you are sure its good, pull grenade pin on tension-er.
Rotate engine clockwise slowly and feel for any resistance (valves).
Install motor mount to engine with 3 bolts (14mm) 33lbs, and then the 10mm bolt on top (9 lbs). Use thread-locker on the bottom bolt as it was from the factory.
Install motor mount to frame (3x 17mm) and connect to engine mount (2x 14mm)
Install timing belt keeper washer on crank
Install lower and upper timing covers
Install power steering pump - 12mm PS bolts, 16lbs
Install crank pulley and crank bolt, 47 lbs plus 60 degrees, or 181 ft lbs, with engine oil on bolt flat and threads
Install drive belt tension-er assembly - 17mm, 54lbs. 12mm, 16lbs
Install drive belt
Install radiator drain petcock
Reinstall/reconnect radiator overflow tank and power steering reservoir
Using special radiator funnel, Refill radiator with blue Honda rated 50/50 fluid.
YouTube
YouTube
YouTube
https://www.youtube.com/watch?v=_zD43KvKmgQ
https://www.youtube.com/watch?v=s5XXcMrE6GU
https://www.youtube.com/watch?v=dS4Ykw9ysP4
https://www.youtube.com/watch?v=0NKb9XgVS_Q
Damn good write up hopefully we can make this a sticky!
Remove drive belt
YouTube
Remove timing belt
Install drive belt
YouTube
YouTube
YouTube
My thumbs up is for the attention to details. Nice write up. Thank you. I'm not for using the starter to remove crank shaft pully bolt. Although I know of no one who caused any damage using this method. I do know of someone driving around an Honda Accord V6 with broken flywheel teeth.
Remove drive belt
YouTube
Remove timing belt
Install drive belt
YouTube
YouTube
YouTube
Premium Member
2005 Pilot EXL- 227,700 Miles
Checking for mismatched cams vs TDC Cylinder #1- I have noticed 3- small groves in the drive pulley (accessory belt pulley) then 1 small groove about 30 degrees after while rotating crank clockwise. I am thinking the last one is for TDC for cylinder #1 and is supposed to align with the lower timing belt cover. Is this right?
Different engines have different marks and there are two different engines for the 2005. I have the 2005 Ody manual and a 2006 Pilot manual (I don't have a 2005 Pilot manual) and both show two marks on the crank pulley that are close to each other. It shows to put the second mark on the timing cover pointer for #1 TDC. You really should have the service manual for the vehicle you're working on. I have seen plenty of people use the wrong marks on the crank pulley and/or the timing cover.
I here what your saying, but I've done timing belt jobs on various years, models, 4 and 6 cylinder Honda's and have never once been confused about what marks to use.
If you're doing a timing belt replacement job on a car with no issues it's easy since the cams will be on their marks and you'll see the crank mark line up. You simply line it up in the same place with a new belt. That's easy. However, If you are troubleshooting a car with a problem, trying to rule out a timing issue, and you've not worked on that particular engine before, you need to know which mark it is in order to confirm proper alignment.
Premium Member
According to my 2005 Pilot Service Manual- it only shows 2 @ Ignition Timing marks but I have 3 thus my initial confusion. See picture. Also note that the FSM references “White Mark” which is after my 3 marks rotating CW. Obviously a mechanic highlighted the mark on pulley as I can barely see the groove in pulley but it is there to the best of what my eyes are telling me. The picture was taken with the Rear Cam Marks aligned up dead on. I will post more pictures that show the Front Cam in relation to Rear Cam which remains lined up. Also note that Crank would have to be rotated CW about 1/2” to align with it’s pointer. Anybody seen the 3 marks that I have and will confirm I headed down the right path?
Premium Member
Front Cam Marks as Rear Cam is Aligned:
Not sure if being off 1/4" between cams is acceptable. Pilot runs rough at Idle- but Great everywhere else. Definetly need Valves adjusted but want to make triple sure that 1.) Present alignment is ok to move forward on valve adjustment or 2.) need to get cams and Crank ALL Re-Aligned prior to Valve Adjustment.
Any feedback is appreciated
Thanks!!
It's hard to tell for sure with the covers on. If you're having issues it might be worth pulling the covers off to see the main marks inside. It looks like it might be a tooth off but camera angles can make it look deceiving.
Premium Member
I agree. Especially when you have to look at it with a mirror and trying to make it perfectly perpendicular to cover/pulleys! ;)
Premium Member
For those that prefer not to download pdf:
Front Cam has to rotate CW 1/4” to align marks
Front Cam with Rear Cam Aligned
135646
Premium Member
Mechanic refused to look at Pilot at my house. I will be taking it to his shop for him to correct his mistake next Wednesday. He did request pictures and I sent him a video. We shall see what happens- stay tuned as the saga continues...
1 - 20 of 43 Posts
