I watched a video on youtube on how to unload the auto tensioner and its telling me for 03-08 pilots, it uses a 14 mm socket. I pop the hood on my car and instead of a bolt i see a slot on where a T bit should be placed :/??? Is it normal for 2008 pilots to use a t bit instead of a bolt to unload the serpentine belt? Help please
08 EX-L, 07 LX
Probably been replaced with aftermarket. If you’re unloading the correct fastener should still work as per designed.
Its the pulley thats infront of the powersteering pulley but a little more under it if that makes sense... could it be the bolt fell out?
08 EX-L, 07 LX
So all the aftermarket ones on rockauto look like this
142721
torx bolt on the one pulley.. I have 4WD which is a different tensioner so I haven’t touched one of these in real life but I feel like the hex nuts cast into the assembly are probably used to loosen the tensioner.
