1 - 11 of 11 Posts
Today I had a scare that I never thought I would see happen. Went shopping, came home put the car in park. Took in packages and when I was coming back outside to move the pilot to the garage, it was doing so all by itself. The only way I could stop it was to have it crash into the back wall of the garage. I have no idea how this could have happened as I walked from the car to the house, put down packages and was heading back out and the car was 1/2 way in the garage. Luckily no major damage, just concerns. I read some post about pilots accelerating in when being put into park .. put this is when all was out of the car and the car was still running in park.
anyone ever had this happen?
I'm not sure what I am reading. It is very difficult to understand.
Did your car move when you were not in it?
Did your car hit the garage wall?
Was it still "in park" when you got back in?
Did it roll forward or in reverse?
it was no longer in park.... which I have no idea how it wasn't as you have to step on the break to change the shifter. the car went forward
Sounds like you inadvertantly failed to put her in park when you got out the first time. Or your garage is haunted. Pick the explanation that seems more reasonable to you.
Good luck.
Are you certain you put the car into park? Perhaps it was placed into neutral and the car rolled forward. When you got back in, was the car in drive?
2016 Pilot has done it twice. 1st time, I put in park to get mail and when I put it back into drive it took off up the driveway.2nd time, I was exiting the carwash; I put it into drive out of neutral and it took off with me pushing the brake down as hard as I could to keep it from running into the vacuums. I took it into dealer and told them that I wanted it checked and on record that if they read about an old lady driving through the grocery store it was not because she pushed the gas pedal instead of the brake. Very scary feeling...
1 - 11 of 11 Posts
