1 - 20 of 44 Posts
Anyone had a mouse problem. Have one resident as of yesterday. Always closed up, so it was able to enter through some part of the exterior or under the hood. It happened to my Acura and the thing died somewhere inside. Had to junk the car. Am trying to trap it but the larger problem is how are they getting in??
I have heard of this on other Honda cars.
Wow
I was trying to run some wire, and I think the Pilot is about one of the tightest vehicals I have seen (at least for SUVs and Vans).
I would think the only way into the car would be through the air intake in front of the windsheild.
It should be screened, but have to look to be sure.
I would check if he had dinner somewhere on the fire wall. Most likely where wires go through it.
Discussion Starter #4
Good point on checking the firewall. The air intake is screened and no munch marks on it. My only thought was from inside the front fenders.
Very troubling especially if the thing croaks.
When it happened in the Acura it would have meant taking out the firewall to get at it cause it died at the heater core. And that didn't stink much when the heat was on.
Run the heat full blast
Get out of the car and Run the heat full blast till he is dehydrated!
Hmmm, wonder if this is animal damage per your insurance coverage?
Might be worth a call.
I had a sister that found herself stuck on vacation this last summer. Seems the vacuum lines had been chewed up pretty good, finally gave out. I would be more worried on what happens in the engine compartment rather then the inside.
D-Con to the rescue.
I know you would rather not have the mouse die inside the Pilot; but eventually it will eat something you don't want it too and it could be costly. The reason animals smell when they die is the blood deteriorating. D-Con will cause them to be dehydrated and they will leave the Pilot in search of water. They will then bleed to death internally and probably not make it back to the car. YUK, I didn't realize how blood thirsty this sounded. In any event, even if they did get back to the Pilot, it shouldn't smell as badly as if they died for some other reason. Good luck. Once had squirrels in the attic (house, not me) and it took forever to get rid of them.
Re: D-Con to the rescue.
copilot said:
...D-Con will cause them to be dehydrated and they will leave the Pilot in search of water. They will then bleed to death internally and probably not make it back to the car. YUK, I didn't realize how blood thirsty this sounded. In any event, even if they did get back to the Pilot, it shouldn't smell as badly as if they died for some other reason. Good luck. Once had squirrels in the attic (house, not me) and it took forever to get rid of them.
Great I was just about to go to lunch.:16:
Discussion Starter #9
Images of the guy eating mouse sanwiches in some movie long ago. All good but I'm trying to find the entry point, because once one has sneaked in it's only a matter of time before there are a hundred.
As I mentioned one croaked in my Acura and I had to donate it, the car that is. Still smelled after a year.
DECON under the hood may be an answer. If the thing can find the way out.
"Never Cry Wolf" yumm......
Don't put the D-con under the hood.
They love the stuff, you will have them everywhere. Put the D-Con near the Pilot in the garage, carport, etc; but make sure you put it where pets can't get at it. The idea is to make them leave the Pilot to get to the D-Con, not the other way around.
C'mon let's be humane ... Haven't you seen Stuart Little ...
See what happens PrG
Look what happens when you aren't around for a while. :eek:
I am torn with guilt ... vermin or no vermin .... !
PrG
Glue Traps
Use a sticky glue trap. At least you know that you got him out of the Pilot this way. No bloody mess.:1:
Yeah and then you can feed him some Decon!
Ooops, please not PETA!
YUCK-A-MUNGO!!!! :16:
Re: Keep mouse amused!
SteveLuman said:
Build the mouse a mousetrap car so he won't need the Pilot:
We have to build moustrap cars in tech! Maybe I'll make a mouse car rental service! :D
1 - 20 of 44 Posts
