1 - 20 of 43 Posts
Hey everyone!
I have an '03 Honda Pilot. 205k mi.
I have had 0 mechanical issues! I live in a heavy winter state.
Stereo no longer works, door handles chipping, seats torn up, vents broken.
I have a new job, was thinking of buying a new $10k AWD vehicle of some sort, potentially with better gas mileage... but also want to put some money into a car cosmetically/performance wise.
What do I do?!?!? Should I keep the Pilot and put another 5k into making it the best version of it's self it can be and take it for another 100kmi?!?!?
How's the rear subframe? Known to get pretty rusty and disappear in heavy winter states.
I purchased it originally in Colorado, very minimal rust honestly. 0 body rust. Just a bit on the underside of the exhaust. Not sure about the frame or subframe. Thinking I'm going to take it in for a complete inspection..
2019 Pilot EXL AWD
If the subframe is minimal on rust, I will keep the car. Spend a 10K on a used car not knowing what the real issue as to why the previous owner want to get rid of it, will be a headache.
I'll invest on seat covers and by going to a body shop to get the subframe look at and see if rust can be removed or minimized. Even getting your car painted won't cost you 5K and knowing your car has 0 problem, I'll keep it.
Take $1k out of the $10k and put it into improving/fixing anything on the Pilot. Put the rest into savings. The next time sometbing major breaks, dump the pilot and get yourself something else.
It’s only cheaper to keep an older car if you can rely on it. If I can’t drive the car anywhere I want and trust that it’ll make it to my destination then it’s not worth $1 to me. Any car can be made reliable but it’s just a matter of how much money you’re willing to put into it.
Is it worth modding out though 🤔
When is the next TB/WP due?
Take it in for an inspection? You can't look under there? LOL
Not exactly sure, I may have to pull up a carfax of its service records xD
I mean, in general I want a full inspection done yeah, in regards to the rust, 0 frame/subframe rust from what I can see!
The Timing belt should be done every 105K miles, or 7 yrs. But you knew that.
If it's due- unless you DIY, that's around $1200 in most areas.
If you can't see the rust underneath, neither are they.
They may check the control arms, and such- that you can't necessarily just look at though.
One rule of thumb is it's usually cheaper to fix the current ride, etc.
Congrats on the new job!
Reactions: plplplpl
If the subframe is good, I'd look to keep it. Everything you mentioned can be fixed with relative ease. Even if you are in line for a new timing belt you'll still be at most 1/4 the cost of the "new" vehicle. Start setting aside $300/month or whatever for a down payment on the next car and when this one finally gives up on you I bet you'll be pretty happy with that down payment.
Reactions: The Todd
Hey everyone!
I just replaced the bottom seat cushions for $15 each - decent condition, picked up replacement rear vents $2 each at a U pick salvage yard. I also replaced one of the front middle vent louvers.
Discussion Starter · #15 ·
Where did you find the seat cushions? Awesome good Idea on going to a salvage yard. I should do that!
All you have to do is crawl under the rear bumper and inspect the unibody crossmember that the subframe attaches to for the condition. Heavy rust, flaking and thin metal = big problem while surface rust and patchy rust can be managed. Post some pics for Internet diagnosis.
Discussion Starter · #17 ·
I'll post a pic shortly. I think we are looking good in these regards 👍
What's wrong with putting some nice rims, tint, intake, exhaust, and nice suspension on it? XD
Supercharge? 🤔
Cause it’s a 4 door minivan? Exhaust will make it loud and annoy people. Intake will just pull hotter air or make it susceptible to water ingestion. Rims will probably slow it down, though go for it if it’s your thing. Suspension? - Lipstick on a pig. It’s good at what it does, but most of that stuff only makes it an objectively worse vehicle. It’ll never be sporty, cool, handle well, etc. IMHO Better to appreciate the pure utility it offers and focus enthusiast efforts towards a vehicle that is actually interesting.
1 - 20 of 43 Posts
