1 - 16 of 16 Posts
Just did front suspension upgrade with all MOOG parts. Lower control arms, inner and outer tie rods. I’m replacing 1 year old Gabriel struts because I think they are bad and I was impressed with the Moog parts that I used. I already purchased MOOGs from RockAuto....then I read that they are hit and miss with quality. Crap!
Has anyone have good luck with MOOG parts?
I really don’t want to replace struts for a 3rd time!!!!!
Discussion Starter · #2 ·
Well....for now my suspension saga is fixed.
Turns out the Gabriel struts I installed 13 months ago were the culprit of my noise and potential tire cupping. I installed Moog LCA, inner and outer tie rods last week and the noise persisted. I installed Moog struts and it completely took the noise away. I don’t think I’ll ever put a Gabriel product on my cars again. I gave them a chance to make it right and they didn’t stand behind their product.
Moog for the win!
Note to self: Add Gabriel to list of struts to avoid. Monroe is already on that list.
Your mileage may vary but there were a few other amazon reviews that were bad too. Similar experience to mine....too bad the comments weren’t there when I bought them.
Been happy with the KYB shocks installed in the rear, so I will go with KYB strut assemblies in front when the time comes.
I too will switch to this. Other than the bounce test its there a way to check physically that struts/springs are bad? Mine appears to be more "lifted" in the fronts. Don't see any tire wear per se. Wondering if this is my imagination. Is there a gap distance from tire to fender measurement?
I didn't measure it, but I eyeballed a little bit of sag at the time, plus a bit of negative camber, although the latter can be remedied by installing adjustable rear upper control arms.
I'm shopping for parts at RockAuto; for the KYB Strut-Plus there is only 'AWD', not '2WD' or 'FWD'. Is there a difference in the front shocks between the 2-wheel drive and 4-wheel drive (2008) Pilots?
Not sure but when I enter a 2008 2-wheel drive for that same strut on Amazon or CarID or NAPA, it doesn't show as compatible. Your 2008 FWD also has a slightly different engine configuration in that it has VCM, so there may be some differences (although I can't think of why offhand) for the struts, so I wouldn't risk it without calling them first and getting a straight answer.
Look for leakage, bent or damage to the housing or strange clunks and noises going over bumps or how the vehicle handles imperfections on the road. If the front appears lifted perhaps you have a sagging rear due to weak worn springs. Tire wear or cupping etc may be evident or take some time to appear to the untrained eye.
Moog is starting to become a parts vendor to avoid also .. build quality among other reasons
Reactions: headknocker
Thanks for your advice. I contacted KYB; they show "AWD" because they only have the stiffer spring for the heavier AWD Pilot. I don't really want to stiffen up my ride, so it looks like I will have to buy the strut and 2WD springs (unless I re-use my 175,000 mile springs), and the other parts, separately and then assemble them.
Good info. But by the looks of the picture in your signature, you're less light. :p
By all reasonable criteria (like above, and the bounce test), my OEM struts were fine at 135k, but I thought the ride was terrible. The vehicle felt floaty and the steering was vague. It reminded me of driving a brand new Lincoln Navigator I got as a rental 20 years ago and hated.
New KYB strut plus fixed it right up. They're quite firm for 10k miles, then smooth out. If you have more than 100k on what you've riding on, you got your money's worth. Replace them and enjoy.
1 - 16 of 16 Posts
