21 - 31 of 31 Posts
· Premium Member
· Registered
Discussion Starter · #22 · (Edited)
Monroe Shocks
The Monroe Sensa-Trac Load Adjusting rear Shock Absorbers 58645 size is made for the Odyssey rear suspension. But will fit the Pilot with similar rear suspension, But the Monroe web site doesn’t show this 58645 size rear shocks as fitting the Pilot, But If you look at the specs for Pilot replacement rear shocks and the 58645 size rear shocks, they are similar close in specs.
· Registered
Discussion Starter · #23 · (Edited)
Specs
"Monroe web site references"
58645 Sensa-Trac Load Adjusting Shock Adsorber
Product Specifications
Applications Where Used Honda Odyssey 1999 - 2004 Rear
Mounting Code Loop Bushing& Sleeve Mount - 1/2" Sleeve ID X 1.1/2" Sleeve OAL
Lower Mounting Code Loop Bushing& Sleeve Mount - 1/2" Sleeve ID X 1.1/2" Sleeve OAL
Compressed Length 11.360"
Extended Length 17.320"
Travel Length 5.960"
Spring (Rate) 45
Dust Shield Yes
Parts Pack(s) None
Extended Hydraulic Lockout No
Compressed Hydraulic Lockout No
Extended Bumper Stop No
Compressed Bumper Stop No
Dust Shield Material Metal
37246/Rear Shock Absorber
Applications Where Used Honda 2006 Pilot Rear
Upper Mounting Code Loop Bushing& Sleeve Mount - 1/2" Sleeve ID X 1.5/8" Sleeve OAL
Lower Mounting Code Loop Bushing& Sleeve Mount - 1/2" Sleeve ID X 1.5/8" Sleeve OAL
Compressed Length 11.500"
Extended Length 16.875"
Travel Length 5.375"
Dust Shield Yes
Parts Pack(s) None
Reactions: 2_Stroke
· Registered
Spring (Rate) 45
Dust Shield Yes
Parts Pack(s) None
Dust Shield Yes
Parts Pack(s) None
please keep us informed on ride quality
· Registered
Discussion Starter · #26 ·
Monoroe rear shocks
No more bottoming out or rear end sagging when loaded down with eight and the hitch carrier on and still a smooth ride when empty
Reactions: 2_Stroke
· Registered
An old thread but also a very useful one. Monroe 58645.. Does anyone have a long-term update using this coil-over shock as far as ride comfort on rough roads including gravel on 1st gen Pilots? Also, has anyone experienced a broken shock chassis mount since these mounts are not really designed to carry weight but now will with the addition of this shocks coil spring? I'm trying to decide between this coil-over shock or Firestone airbags to help reduce my 06 Pilot rear-end squat. I'd be concerned the airbags will wear out or puncture from off-road use. I have already replaced the coil springs with Moog 81649 HD springs but still getting excessive inside rear tire wear. I cannot find worn parts and rear toe-in is in spec but camber is far too negative with any kind of load.
· Registered
working on this myself right now - 08 - tows alot. not sure where to start - all oem rear susp. w 200,000 mi. - atrocious inner tire wear. where to start, where to start. springs and shocks b4 adjustable camber kits? seems to make sense to me but Im no mechanic and thats an understatement!
· Registered
2008 Pilot, 1989 Civic DX 3dr 5mt
Yes... OP's signature shows he has an 06 Pilot... not sure about the year of the oddysey.
I'll dig around a bit more at Amazon, Monroe, Sears, etc... to see if numbers are the same for 03/04 and his 06. Clearly his pics show this uber-cool shock fits 06's.
58645 load adjuster fits 1999-2004 Odyssey, no listing for Pilot but if you match up sizes, it works. Will be installing on 08 Pilot EX-L soon
21 - 31 of 31 Posts
