I would like to upgrade my headlight bulbs to some LEDs, they have improved a lot recently & produce a proper cut off beam.
My Canadian 2005 has daytime running lights which sends 7 volts to the high beam, this will not work for the LED bulbs so I was wondering if there is a way to modify the DRL system to reroute the voltage to the side lights instead of the high beam.
Sent from my SM-A705W using Tapatalk
Discussion Starter · #2 ·
Anyone have a wiring diagram that shows where the DRL voltage comes from, out of main ecu or a separate component?
