1 - 17 of 17 Posts
On the top of my steering column is a small, approx 1.0 x .5 x .5 inch, hole with a smaller hole at the bottom. It looks like it should have a cover over it, but none is present. Should I ask my dealer to order one, or is this the natural state?
Should be there, dude...
The cover is a dealer prep item.
When I test drove mine there were 4 or 5 bags of small seals and plastic bits (including the one that's missing) in the glove compartment.
Mine didn't have the pen clip in the center console.
The dealer got one in about a week.
They should be able to to the same for you.
When we picked up our Pilot, we also found the cover missing, but later found it in the glove compartment.
:29:
When I picked mine up, I noticed the hole in the steering column and the sales rep reached into the glove compartment where the cover was stored in a small plastic bag.
I found that mine had been put in upside down, turned 180 deg. The tabs on the piece are not spaced the same on each side so make sure you look in the hole to match up the tabs. Mine had been forced and all the tabs had broken off.
john
MIne was placed back in during the dealer prepped but noticed that the area was all scraped up ... like they could not find the hole in which to pop it out ...
PrG
Anyone have a picture of this pen clip or can descibe where it is and what it looks like? I haven't seen anything in my center console that would qualify as a pen clip, but I did have a few pieces of plastic in a baggie (maybe one of those is it!).
pen clip
It is a pen clip that you can really clip a pen, on the top part of the flip out consel that has the cell phone clip below it.
Look into web site that show the cell phone crandle, you may see the pen clip also.
the picture
Go to the gallery section, go to the Pilot photo site.
Go down to the one showing the flip out consel with the cell phone crandle, at the tip of the phone's antenna, there is the clip and the indent for the pen.
hope that helps.
Re: the picture
Thanks. I guess I just didn't notice that.:confused: The area next to the cell phone then must be the post-it holder. I guess I'll have to go get some post-its now.
hope that helps.
Business Cards
Think I saw some literature that this area next to the pen clip is for business cards . . . . that's what I have there anyway.
Why is this access cover a dealer prep item? What inside the sterring column does this hole access?
:confused:
Opening on steering column
It's a bypass to the transmission interlock. If the interlock won't release (maybe your towing it with a dead battery) you insert the key into the hole to shift it into neutral.
The notepad holder is under the cell phone holder (it must be removed to use it). The space to the right of the cell phone holder is for business cards (works great).
My cover was there but not completely in. I lifted it up and the dealer had bent the four prongs trying to force it in the holes. Rather than make a big deal about it and figuring I would never use the shift interlock anyway I bent most of them back (although they were about to break off) and stuck it back in.
Missing Cell Phone Cradle
Mine is missing the cell phone cradle. They are looking for the replacement. Here is a picture for those who wonder:
1 - 17 of 17 Posts
