Check transmission fluid known issue of transmission cooler tank leaking into radiator.
Search for SMOD.
Search for SMOD.
Had my oil changed on Thursday last week. This happened Friday. Today the oil on the dipstick showed no signs of contamination. I'll check the transmission fluid in the morning.05 is known for bad Denso radiators. That in time allowed coolant to mix with ATF. Hopefully coolant hasn’t found it’s way into the transmission.
But yes, a blown head gasket can mix engine oil with coolant.
Check oil and transmission for contamination.
There is a chance that the atf or oil contaminants the coolant while not contaminating the engine or transmission fluid. Hopefully that’s the case. My advice would be to not run the vehicle.Had my oil changed on Thursday last week. This happened Friday. Today the oil on the dipstick showed no signs of contamination. I'll check the transmission fluid in the morning.
Haven't ran it since it happened. Just trying to figure out where to go from here.There is a chance that the atf or oil contaminants the coolant while not contaminating the engine or transmission fluid. Hopefully that’s the case. My advice would be to not run the vehicle.
Your engine oil looks clean. Can you get a sample of atf? Clean ATF is pink/red, but old used ATF can be brown. The fact the ATF is low is a concern.The trans dipstick isn't showing much of any fluid on it, which raises other concerns. Here are pictures of the oil dipstick and the fluid in the overflow tank. View attachment 168668 View attachment 168669
I’d open the drain plug to see the ATF condition. Reach in under the front bumper, an pop in a 3/8 ratchet (No socket), and pull to break loose.This is all I could get off the ATF dipstick.
I’m not seeing any hint of red on that rag. That, the tranny fluid level being low, and the tan mixture in the coolant overflow reservoir aren’t looking too hopeful. What color is the coolant in the radiator?This is all I could get off the ATF dipstick.
I’m holding out with a little hope that if it is ATF mixing in the coolant, that it pumped out of the transmission and not back in.I’m not seeing any hint of red on that rag. That, the tenant fluid level being low, and the tan mixture in the coolant overflow reservoir aren’t looking too hopeful. What color is the coolant in the radiator?
Having a rough time getting the transmission plug out. Here is what the coolant in the radiator looks like.I’m not seeing any hint of red on that rag. That, the tranny fluid level being low, and the tan mixture in the coolant overflow reservoir aren’t looking too hopeful. What color is the coolant in the radiator?
