1 - 2 of 2 Posts
Anyone know anything about this TSB covering the following vehicles?
MIL Comes On With DTC P1457: EVAP Bypass Solenoid Valve Failure Bulletin
Models and Years Covered
Accord 2003
Civic 2003
CR-V 2003
Insight 2003
Odyssey 2003
Passport 2003
Pilot 2003
S2000 2003
Original thread
My check engine light came on about two weeks ago and the Pilot started running a little rough when you let your foot of the gas. After checking to make sure it was not the gas cap problem that could casue the check engine light I took it in to the Dealer. He was not sure what was casuing the problem at first but read the same TSB and when he replace the valve everything worked fine and the Pilot is running much better. By the way the Pilot has 16k miles now.
1 - 2 of 2 Posts
