Any common issues to look for on an 09 4x4? 159k miles? Will it last another 100k?
And threads on here with a common issues list?
Look for documentation that the timing belt/tensioner/water pump has been performed.
Ask if all the recalls have been performed.
Ask if the Pilot has been burning a lot oil.
Check for idiot lights are not on after starting engine.
Check that the AC is blowing cold air in the front and rear vents.
Take a good test drive to see if you feel any sluggish shifting of the tranny and any clunking noises coming from the front end.
I've never had a problem with the VCM but many have.
Also, catalytic converters will need replacing in the near future. Routine valve adjustments should have been performed, along with everything the member above stated
