1 - 13 of 13 Posts
Does anyone know where to source the middle row seatback pegs? One ot the backs came off and the dealer wants $10 per peg. I don't know what they're called other than pegs, so its hard to search on Rick Auto and Amazon. I don't have a part number. Any help would be appreciated. I am an original owner since July 2002, so I'm cool.
Post a photo.
Reactions: Ferdball
Search on Amazon or eBay. You can find 25 packs (non-OEM) for around $10.
The genuine OEM part (90600-S3V-A11) seems quite pricey on both Amazon and eBay.
https://www.amazon.com/Genuine-Honda-90600-S3V-A11-Rear-Upper/dp/B00P53QAHY
https://www.ebay.com/p/1522143128
But if you're sure you can find the same part aftermarket, maybe you can get it cheaper. Otherwise, some dealers seem to have better prices, believe it or not.
https://www.bernardiparts.com/Honda-CLIP-RR-SEAT-UPPER__90600-S3V-A11.aspx
From the picture it is not clear if they are snap rivets or not. I would buy a few $5 packs of different sizes from the ebay if they are.
If you only need one, just buy what you know will fit from the dealer. $10 is better than buying a bunch of different things you aren't sure will fit.
So, other original deal sources are a little cheaper, but are still $6.41 each. Packs of clips are a few bucks for a bunch, but I can't find any that are equivalent. The clip that I picture is not a pushpin-type, and the bend is real. I guess I have to bite the bullet and buy several of the originals at $6.41 each.
You've probably already taken car of this, but I have found similar clips at Autozone. At my local one, they have a carousel full of packs of different body clips. Works out to less than $1 per clip, IIRC.
Am I the only one who picked up on this? I think you are AWESOME for being the original owner!
All kidding aside, I hope you got the right clips. I need a couple for my 2nd gen's third row 40 seat but it remains down and covered with a rubber cargo mat 90% of the time, so it's literally been covered up and out of sight.
Reactions: Ferdball
July 2002 would be the very first batch of Pilots. They did not even have them in my local dealer till August I thought. I never buy first year of a new model (burned on a 93 Integra) so waited till Dec 2003 and got the 04 model and still have running strong. As for clips I always get them off E-Bay or Amazon. Doesn't have to be the exact same as long as it holds.
If you want to avoid the clips altogether use some good glue and Velco across the panel.
1 - 13 of 13 Posts
