Both of the warning lights came on after I got my rotors repaired today. Took it back to the shop. After an hour they said that they couldn’t find anything wrong. Reset the warning lights. This evening the lights came back on. Any ideas before I venture back to the shop in the morning??
Thank you
Scott
Float can get stuck in the brake fluid reservoir. Tap on it if it's not floating.
Broke a sensor when they did the brake job.
Reactions: aggrex
Cause is damaged or moved ABS wheel speed pickup(s), undoubtedly done as part of or during the rotors replacement. The VSA and ABS both depend on knowing individual wheel speed, and are complaining about missing data. Your brake guys are in denial.
