Hi Guys,
Does anyone know where I can get a hold of a maintenance schedule for a 2018 Pilot?
Thanks,
Pat
Are we to presume that you don't want to follow the maintenance minder prompts?
No. Does the maintenance minder tell you exactly what needs to be performed at each service? I wish I had an actual document that explains the service schedule so I can see what needs to be performed in the future...
Yes - when the oil life gets down to 15%, or less.
Two exceptions are that the motor oil should be changed at least annually and the brake fluid should be changed at least once every three years.
This info is in the owner's manual.
Since the maintenance minder was introduced Honda no longer provides a maintenance schedule.
See if the chart in the following thread has the info you want:
https://www.piloteers.org/threads/maintenance-minder-updated.159675/
Out of curiosity, how far in advance do you need to know about future service requirements?
