I was wondering if anyone could help me out.
When I start my Pilot, the Maint Reqd light flashes for about 7 or 8 seconds.
It may be normal and I have just not noticed it before. But now its bugging me to find out.
Could some of you guys check your pilots and let me know if they do the same?
Robinson
Depending on the mileage.... might be oil change time.
Robinson
I have had my Pilot for two months, and the light has never come on yet, but it does not require service yet either.
I believe once the you have serviced you Pilot, the dealer should have reset this warning light.. If you do not need service, then take it in to get it reset.
rob
the instruction to "reset" the light are in the manual. it's a simple procedure.
Flashes Then Steady
It flashes 1st then goes steady as you get closer to recommended maintenance mileage. As davemac noted, reset instructions are in the manual under Instrumentation and Controls, page 69.
It flashed after 6000 miles and becomes steady at 7500miles:)
Discussion Starter #7
Thanks for the help.
Thanks for all the help guys.
I had My Pilot serviced by the dealer at 5000 and they probably did not reset it.
Thanks Again,
Robinson
