Finally (after 6 months) got around to installing new rims. Limited my choices to those I felt strong enough for the weight of the Pilot. I preferred those at least 1600 lbs load rating, the higher the better.
These ICW Racing 077M wheels are load rated at 1900 lbs.
See previous thread:
http://www.piloteers.org/forums/showthread.php?s=&threadid=1919
Stayed with 16x7 rim size 42mm+ offset and reused original Bridgestone Dueler H/T 684 UTOG 300BB 235/70-16 tires. I'm satisfied with the performance of the tires so far, though was tempted to change to 17 inch rims, then would have replaced with Michelin CT's or Goodyear Forteras.
I feel SO much better driving around town when I see other EX drivers (haven't seen another LX in months) now that I have removed those plain "styled" steel wheels!
Discussion Starter #2
'nother view
Discussion Starter #3
full side view
btw only thing worse now is the rust on the wheel hub and part of the brake disk is more visible when up close.
Individuality!
Great job and sounds really well thought out. As the Pilot gets a bit older it's cool to see more individual styling cues come out.
Thanks for sharing!
Don
