1 - 20 of 42 Posts
Hi Everyone,
Recently bought a second hand 2008 Pilot and noticed the spare tire change kit (jack and wrench) is missing. What other tools can be used to turn the 5point stem that lowers the spare? A 10mm socket almost fits, but doesn't grip the 5 point pattern.
Thanks.
Miss our 2005 Pilot
Welcome to the forum. You might get lucky with a standard socket instead of metric. Or perhaps hit up a junkyard to see if you can find the spare tire kit.
Super Moderator
On my 2004 Pilot I used a socket and ratchet then switched to my M12 Fuel cordless ratchet to lower the spare tire down without any issue. Select the best fitting socket for best results.
2019 Pilot EXL AWD
A 21mm socket would work if the original tire wrench is used.
Well with out a jack and handle with the proper socket for the Honda lug nuts, why would you need to lower the spare? If you can't jack up the vehicle and remove the flat, there's no reason to drop the spare. ;)
I would suggest that you get a jack of your choosing, I prefer bottle jacks to scissors jacks, and a tire wrench with a 21m socket and keep them in the vehicle.
Remember that it's not the emergency jack's lug nut wrench bolt size that lowers the spare, but a smaller size one deeper inside it that does.
Quando omni flunkus, moritati.
BTW, like that your signature is a famous Latin-Canadian one. :)
Red Green
Thinking of adopting this one as mine:
"If the women don't find you handsome, they should at least find you handy."
2019 Pilot EXL AWD
For the 2016 and above, I know it's a smaller one. I think mine is either 14 or 15mm
Yeah you got it right. Small 5 point male. I saw some vids of how to and it shows the smaller section inside the head of the OEM lug wrench.
Discussion Starter · #11 ·
Hey everyone, thanks for all the input!
I just tried again with the sockets and no luck. 10mm fits nice but won't bite the 5point, and 3/8 is too small 7/16 too large. Trying to attach a picture from my phone but a security error occurs.
I called a couple wreckers in the area which can't say for sure so I'll go for a drive next weekend and check them out.
I want to eventually put a full size spare under there. I have two extra oem rims with rubber. Need to find out if the cable pulley even works :) or seized like I read on other posts here.
Cheers
Full size spare is an excellent initiative. In my case the hoist was seized and I had to get a new one. I now lower and lube it up at least once a year, usually at the same time I put my snows on and go for rustproofing in the late fall.
2007 EX-L
My hoist was frozen as well, replaced it. You might try one of those "Gator Grip" sockets in the mean time. I see the handles in the junkyard all the time. Probably cost you $5.00.
Miss our 2005 Pilot
This is a great idea. What do you use as the lube?
I put Triflow Superior Lubricant on the cable the last time I had the spare lowered. You just don’t want a lubricant which will attract dust and gum up.
Discussion Starter · #17 ·
It sounds like my garage door lube would be a good choice too as that doesn't attract dust, dries well, and prevents rust.
A staggered combination of Fluid Film and removing the spare altogether when I go in for my yearly pre-winter rustproofing, so the whole exposed underside gets the full benefit of that love spray.
But all you really need is silicone lubricant spray.
Okay, so if I understand you correctly, when YOU get YOUR yearly pre-winter rustproofing YOU are using WD40 so YOUR whole exposed underside gets the full benefit of that love spray? 🤣
148721
This stuff works really well. A nice heavy duty lithium grease. They say it won't wash off and they are right.
148723
Besides they are a nice Canadian Company.
White lithium you say,. :) good cause I bought this the other day for the sun roof rails. I'll spray the s*** out of the wench ...
148751
** Got a line on a OEM lug wrench,. picking up in the morning. Will snap pictures and update how it goes.
1 - 20 of 42 Posts
