1 - 15 of 15 Posts
I have a loud ticking noise when I start up my 2013 Pilot. It only lasts about 5 min. Does anyone know what that could be?
It's really hard to say without hearing it. But the first thing that comes to my mind is a valve needing adjustment. This is just a wild guess.
First thing to do is check all the spark plugs to make sure none of the plugs are loose. Second, could need a valve adjustment .
And it would disappear after 5 min.?
Reactions: Mcmanut02
Sounds a little like an exhaust leak, like a manifold crack.
Grab a piece of rubber vacuum tubing that fits in your ear. The other end of the tubing is a handy noise-source probe that may help you isolate the source.
Exhaust manifold cracks are interesting, as they may close up when they heat up some. Sometimes a little welding will temporarily solve the symptom, but the permanent remedy is replacement.
That's sounds like a failing timing belt tensioner. You likely need a timing belt job.
I would not run the vehicle. If the belt breaks, the engine is toast.
Reactions: 311042
Reactions: briantii
Discussion Starter · #14 ·
That's honestly what I thought it was, but wanted to see what you all thought. I haven't replaced the timing belt yet, looks like I'll be having that done this weekend. Thank you so so much!!
Glad to help.
I highly recommend the Genuie Aisin Timing Belt Water Pump Kit (TKH002).
143410
There's a 5% off discount code on this website.
Reactions: briantii
1 - 15 of 15 Posts
