1 - 17 of 17 Posts
2020 Pilot EX-L AWD
Looking to upgrade my 18 inch wheels to 20s. I'm eyeing Beyern Autobahn Gloss Gunmetal 20x10 5x120 +35. If I go with tire size of 275/45R20, would this size cause any problems in terms of rubbing against the inside of the wheel well, steering, handling, etc.? Looking for some feedback from the community. Thanks all.
245/50R20 is the recommended 20" size.
Reactions: Honda7 and Swim Dad
I'm pretty sure that a 275 size tire WILL scrape the wheel well. I think at most a 265 will work but at most I personally would go with a 255 just to be safe if I had to get a big tire. If you can use one, a 245 size will work best with your car.
A few people here have 265 tires with +50 offset with absolutely no issues at all. But 275 with +35 offset might get it close enough to rub turning at full lock... that's an extra 20mm closer to the fender.
2019 Pilot Elite
Theres not a big difference from the stock size but if you make a big swing in the size you may want to plug it into one of these so you can mentally adjust your speed.
On another note, 2 weeks ago I realized my GF's BMW was showing 3-4 mph different from the GPS. A quick Google search and BMW is notorious for always displaying faster than actual speed. I haven't noticed a difference with my Pilot but still worth checking and then comparing.
2020 Pilot EX-L AWD
Highspeedbail
Thanks for the link. Will look into it.
Here is a thread with a minor rub with 265 70 17s.
According to discount tire direct, there should be no issues with a 20x10" +35mm and a 275/45/R20.
For example,
Tires: Pirelli Scorpion Zero A/S Plus (275/45-R20 110Y XL)
Wheel: TSW Mallory, Drag DR-73, TSW Brooklands (some with the 20x10 +35mm)
are listed as fitting.
You can speak with them, buy from them (I have many times) and get them installed. They also give you 100% satisfaction, if it has any problem, even 2 weeks down the road.
That 20” tire is less than 2/10” taller than stock, shouldn’t be a problem but you never know. The 35 offset will move the rim outward a tad over 3/4” compared to OE 55 offset. The 2” wider than OE 8” rim will move the rim inward 1”. Seems like 1/4” net further inward would not be a clearance issue but you never know until one is mounted and clearance checked/verified. If the OE tire is 245, the 275 tire will be 1.18” wider. Something to consider.
2020 Pilot EX-L AWD
For example,
Thanks smufguy. Good to know!
2020 Pilot EX-L AWD
Discussion Starter · #11 ·
Hey PLT383,
I was hoping someone had done this on their Pilot with the specs that I was looking at and basically replying "no issues whatsoever".
Sorry......I wouldn't tell anyone "no issues whatsoever" when straying away from OE tire/wheel sizes. I believe I have a decent understanding of the 3 tire size numbers on the tire sidewall and the arithmetic that applies to those 3 numbers regarding tire diameter, width and aspect ratio. Also, I think I have a reasonable understanding of the arithmetic involved in wheel/rim dimensions/offsets.
Everything smufguy post is good info......talk to the experts, as he recommended.(y) I believe the experts use the same arithmetic I use.👌
2020 Pilot EX-L AWD
Discussion Starter · #13 ·
Point taken. Thanks PLT383!
Post some pics when you git ‘er done.(y)
The 2019-2021 Passports have 20" wheels and tires and dozens of owners have been switching to 18" All terrain set-ups and there are lots of sets being sold. The great thing is that they match the Off-Set of the Pilot (as far as I know). I also know some Odyssey and Ridgeline owners have put the 20" Passport set-ups on their vehicles.
You can pickup an entire set for a super price, the Passport website is owned by the same company that runs this Pilot website, here is the Link:
(I think I my 20" wheels/tires here listed for sale in both websites)
Yep, motorcycles are notorious for for reading aw much as 12% over 'real speed' For good reasons I guess.
Often I'll see a post from a squid how their 600 was doing 180, when real speed would have showed about 155mph.
I have a 'speedo-healer' I put on mine, it's 1-2mph over across the spectrum.
Reactions: Highspeedbail
1 - 17 of 17 Posts
