Welcome to the forum.
Here's a Sticky that should be of great help...
Rust
Clean engine oil
Starts quickly
Engine idle is smooth
Red ATF
Shifting is smooth
Power steering fluid clean
No play in the steering wheel
Brake fluid clean
No vibrations or shakes when driving
When was timing belt water pump changed
Reactions: Charlie Primero
See if you can get the service records for the vehicle. Then compare services performed against the 2005 Pilot maintenance schedule (2006 and newer Pilots use the maintenance minder system so there is no printed maintenance interval schedule).
And welcome to the forum.
Reactions: plplplpl
front wheel drive or four wheel drive? The front wheel drive 06/07/08s are a VCM engine. VCM engines are less desirable.
