It's just the nature of entropy that we're going to be seeing more and more oif this.There are several forum threads on the topic of rusted subframe cross member. It’s a big job and not to be taken lightly. One disconnected rusted mount will eventually result in failure of the other mounts.
Rusted subframe mount repair
I have come up with a solution for the rear crossmember rust issue. The subframe attachment point tends to rust out, and the subframe then becomes loose and unsafe. Please see the attached photos. It is necessary to remove the third row seats and roll back the carpet, and work from both above...www.piloteers.org
Since you got the budget for repairs there’s room in there for an affordable complete Walker exhaust system including the CAT(s). Price it out at RockAuto. Old exhaust work is messy but once everything is cut off and removed the new bolt-on Walker system is fairly simple.
Yessir!Use only OEM Honda power steering fluid and a small amount of seal conditioner (possibly AT-205) to buy some time.
