Hi all! I'm new here and I've been reading about everyone's difficulties with Honda's VCM. I have a 2013 Pilot with 63,000 miles, misfiring with P0303 DTC, and the #3 plug is soaked with oil. I purchased it June 22, 2013. It is my understanding the the warranty was extended to 8 years/100,000 miles for piston rings. Both the dealer and Honda customer service said that my VIN# was not included in that extended warranty and the dealer wants $3K+ for a ring job. I thought all of the 2013 Pilots were covered under the settlement. Is there something that I am missing?
Based on what I've read here, it seems that a VCM disabling device may help, but I feel like Honda should be replacing the piston rings.
I wouldn't feel I was loosing anything by not getting a ring job. In fact, I don't want anyone tearing into my engine. They have to mess with your timing belt and I don't want my tensioner touched.
Many many success stories with VCM disabling devices. I prefer my engine to run on all 6 cylinders 100% of the time. I use S-VCM. I can remember the days when if you had a cylinder not firing, we called that a dead cylinder. It was not a good thing, it was bad. Not much has changed. It's still bad. It still causes fouled plugs, dirty valves, stuck rings etc. S-VCM cost me $95. If I owned another Honda V6, I'd buy another. Helps keep all my cylinders clean and spark plugs dry.
2011 Pilot EX 2WD
You probably already know this but this issue should be resolved by dealer under service bulletin Tsb-13-082.
Not sure why your vin would not be covered.
Yes, I knew about the TSB and I brought that up to both the dealer and CS, but they insist that it doesn’t apply to my Pilot. Unfortunately, I don’t have the time or inside knowledge to fight Honda.
I’m going to try either the S-VCM or the VCM Tuner 2, whichever one I can get the fastest.
