1 - 20 of 27 Posts
Good morning
We've had a 2005 Pilot from new. Never tow with trans and transaxle fluid changed every 30K.
Anyone out there with the same maintenance schedule and how many miles?
Thank you.
PS I don't even want to put a new trans in this thing. 199K.
Have you changed your radiator?
Reactions: 97trophy and aggrex
The 2005 has an external replaceable filter. Have you changed that?
Reactions: ConrodM
Think you got your monies worth out of that transmission due to good maintenance and fortune. Getting 200k trouble-free miles from any transmission is somewhat remarkable because components within do wear out. Small issues that seem to crop up with high mileage are solenoid / pressure switches.
~115k miles on my wife’s 2005 Pilot, so nowhere near the 199k miles yours it at. I’ve been doing a 1x drain and fill every 15k miles, mainly for peace of mind, and no tranny issues thus far except 3rd and/or 4th gear pressure switches going out at ~75k miles (I just replaced both when I got the flashing D even though code reader indicated only one was bad). I’m planning to replace the tranny filter at the next D&F at the 120k mile mark. Radiator was replaced at ~85k miles due to en external leak, and thankfully not the one which results in a pink milkshake.
Reactions: aggrex and ConrodM
Thanks guys for the suggestions. I don't even want to have the tranny replaced. Cost more than it's worth.
I'm probably on borrowed time.
This has been a reliable suv but components do wear out.
I've always had the fluids changed at the dealer's quick lube.
No mention of an external filter. I was under the impression that the trans had two screens internally.
Next suv's going to get more than 16-18 mpg. Problem is getting something I can fit into(6'4").
What about that radiator? Are you aware of the issues where the radiator fails and takes out the transmission?
Reactions: ConrodM
Reactions: ConrodM
Yeah,heat exhangers on domestic trucks do the same. That's why I have a manual truck.
All the new cars and trucks have so many gadgets I can't comprehend how all that stuff will hold up.
Premium Member
2005 Pilot EXL- 227,700 Miles
216k on our 2005 EXL. Had near death experience also (ATF Connection to radiator failure) at 213k. Been thinking of doing 3x drain/fill because I am not sure what the local mechanic put in. It shifts really smooth and smoother in cooler weather (40’s-50’s). Thanks Road2cycle for pointing out the filter- local guy said it didn’t have one that was serviceable. I doubt ours has ever been changed.
Discussion Starter · #15 · (Edited)
355K on our 04 EXL. Stock engine, Trans and Radiator. Because of this "heap", we have 5 Pilots in the family!
That's what I like to hear! My local Honda dealer had a couple of guys from the company swapping out defective autos on the first ones. My service writer used to be a tech and told me to just change fluids and that the trans can go a long ways. Our engine purrs on cold days upon startup. No ticks or nothing.
I bought a new Tundra in 2010, it has 83,000 miles on it. While it's been issue-free since new,if it serves me any where near like that Pilot, I'll be happy!
Premium Member
1 - 20 of 27 Posts
