Going to be changing out the radiator coolant on a 2016 pilot and cannot see the drain plug from the top and it looks like it may be hidden by a plastic mud guard on the bottom? Guess I'm just confirming that you have to remove the mud guard before you can access the drain plug?
Thanks, it does refernce removng the "splash shield" so I guess it should be obvious once I take that off
I sent you a private message shortly after replying to you here on the forum. Check the link I sent in that message for more useful information.
