1 - 12 of 12 Posts
I have a 03 Pilot that I had lifted 3 inches and I know I have to replace my rear springs...(common sag) and my thought was while doing it, go ahead and put load assisting shocks on as well for added support. Has anyone found those spring loaded shocks for our vehicles? Where I live has a bit of rough terrain and I am just wanting to have maximum effort to absorb the road conditions. Any help would be much appreciated.
After cross referencing...I am going with the Moog problem solvers 81649 along with the Monroe sensa-trac 58645 for now...I am hoping there is enough travel to not be an issue but seeing as they are close to factory specs with about 1/2" extra travel extension that it will not be a concern. Waiting for it all to show along with plugs...I like Nology silver plugs.
@aggrex has it covered, most on here seem to go with airbags over helper shocks.
if your in the rust belt, getting the left rear spring out can be hampered removing the control arm to hub bolt. I broke the bolt, had to cut the control arm off, then replace the sleeved bushing.
I had it recently lifted and shouldn't be a problem...as it sits, it only has 55k on it,so it hasn't seen too much yet
Update...from what I can tell. The 58645 shocks would work good for a factory height pilot. I think raising it the 3 inches has the shock over extending and needs a longer travel...after going through basically every part number for the shocks and looking at lengths...I think the 58527 is a better fit for raised ones...I have yet to exchange them as I plan to call monroe direct to see if they tend to agree. I'll post factory dimensions and also that particular shock I was interested in.
135075
135076
Update...58527 seem to have done the trick. I ended up using two washers on the top and botton as the bushing is smaller, but it went together well. The bottom stud is a bit of a bear to line up the shock as you have to compress about an inch of it at an angle to get it lined up, but at least there is a bit of excess travel. All in all, this should work out quite well, so if anyone is in that same predicament, hopefully this will help you out.
1 - 12 of 12 Posts
